Hi all,
I have a 1980 25 HP Johnson Seahorse J25RCSA. and limited mechanical experience. I store boat and motor uncovered.
I took the boat out about a month ago and had some very bad gas (water) managed to make it a few hundred yards and engine kept conking out.
I put the boat back on the trailer and within a week fixed the problem by mixing new fuel and running the motor for 15 minutes or so in the barrel. Two weeks later I put the boat in and took it out to a dive site about ¾ mile away from ramp. Tell tale was working fine. I brought the boat back, did not look at telltale so do not know if it was working. I heard nothing unusual from motor and shut it down with the stop switch. Trailer the boat and brought it home.
Two weeks later, I tried to take it out again and found the motor frozen. Starter rope would not move more than 6 inches and flywheel not at all. I had problems getting it in and out of gear but finally got the prop to spin freely.
Talked to a few people and they recommended I check the gear lube. I did found it to be almost all water. I checked previously the beginning of the season but not since about June.
Removed the gear case and tried to spin flywheel, motor still frozen. Prop spun fine. I put a few ounces of Marvel Mystery Oil (MMO) in each of the cylinders and left overnight to soak. I also filled the gear case with MMO spinning it a few times.
I managed to use a breaker bar on the flywheel nut and free the pistons. Motor spins freely now. I plan to run a compression test on the cylinders in the next few days. . I plan to rebuild the water pump.
My questions to all of you are the following:
How did the water get into gear case? I see no signs of MMO leaking out.
Why did the engine seize to begin with? Was it the bad gas?
If the compression test comes turns out well, what should I consider doing anything else before trying to start it up again?
Should I rebuild the gear case as far as seals? Any other tests I should run?
Can some one of limited mechanical ability do this or is it best left to a mechanic?
Thanks in Advance
Dave
Thanks in Advance
Dave
