Seized Steering
pinoy
Would anyone out there have any ideas on how to free up a steering cable? I think there might be some corrosion causing this problem. Any ideas/thoughts on how to free it would be greatly appreciated.
Backlash
Re: Seized Steering
Hey Pinoy,<br />Not what you're going to like to hear........but you'll probably need to buy a new cable. Generally, they're corroded throughout and it's impossible to free them up. <br />Backlash
oldboat1
Re: Seized Steering
If the cable is hung up at the helm, you might try disassembling the unit to see if you can free it up. It might be a matter of getting some grease in there (thinking of the Teleflex type unit). Try partially separating the front and back of the unit -- just enough so you can move the cable if that is where it is hung up. Then add some grease. If you get the cable moving back and forth, turn the wheel fully right and left until everything moves freely. I don't think the manufacturer recommends this process, but if it fixes the system you will have saved replacement costs. If there is any doubt about future operation, though, -- broken pieces, broken cable -- part or all of the unit obviously needs to be replaced for safety. Be safe.
Re: Seized Steering
I hope this is your problem, I too thought it was a froze cable on my boat, it had been in an accident and the steering was stressed hard, somehow the shaft that slides through the tilt joint was bent just a little on the trailing end of the cable, does yours move here? if not get this freed up first. I tapped mine and worked to smooth moving slide. Saving me a hell of a lot of money and time.Good luck! Ross
pinoy
Re: Seized Steering
I noticed some corrosion at the end of the cable, where it slides through the motor bracket. I tried to remove the bolts and free it but no dice. Not sure what else to try....frustration!!
SS MAYFLOAT
Re: Seized Steering
I had the same problem on my flying bridge last year. The sucker siezed up tighter than a catholic boy next to a priest.<br /><br />There are two ways that I know of forcing lubricant into the cable.<br /><br />1. Get a length of 1" or 1 1/2 inch black ABS water line. (the type that is on a big roll.<br />Cap one end, put your steering cable into it, fill with Transmission fluid. Cap the end after filling it. Let it sit for several days and then pull the cable out. This is messy, but I have had others that swear by this method. (I picked this tip up from other forums) Then try to free the cable by working it back and forth. If it doesn't free up this way, then a new cable is in order. Honestly, I wouldn't trust this cable if it is siezed that bad.<br /><br />2. This method is only good for cables with a good jacket on them. Have a can of tranny fluid. (Not ************ urine) I have used this method and it works for getting the lube into the cable.<br />Place one end into the container where the jacket of the cable is submerged into the fluid. At the other end, take a good strong shop vac, (I used my refrigeration evacuator pump) and put it over the other end and seal it up real good. If you have it sealed up well enough, the vacuum will draw the lubricant up through the cable. Watch that you do not draw a large amount into your shop vac. It will make a big mess.<br /><br />Problem with these methods is the oil can continue to drip out over a period of time making a mess in your boat. <br /><br />I would only consider this a quick fix, and then replace the cable at a later date. The longer the cable, the odds of getting it to break loose is higher.<br /><br />Good Luck
