toystory_4wd
Thread starter- Joined
- Mar 30, 2009
- 8
Hi! I recently aquired a '72 Evinrude 50hp, with the Selectric Shift. I am still putting things together and haven't run her yet. Research has gotten me far regarding the pushbutton shift business (which I could live without, but the motor was cheap) but I haven't been able to ascertain this:
When I push either the forward or neutral button, said button stays down and any other downed button pops up. The reverse button will not stay down. (But the others DO pop back up) Is this a defect, or some sort of engineering quirk designed to keep me from throttling up in reverse (as I only have one right hand)? I'm having visions of trying to hold down the reverse button with one hand, throttle in another hand, and steering with a third, after, of course, having another arm surgically added...
While cranking the engine, neutral DOES engage (when selected) so I'm operating under the assumption that the system is working more or less.
Thanks, all! Cheers- Chris
