Selecting a replacement Prop
BornBlue82
Re: Selecting a replacement Prop
Here is a picture of the prop. It's not really that bad, I just wanted to upgrade.
SkiDad
yeah that is not real bad - so you are probably getting true rpm reading. So your 20 is probably that safe bet as I bet the 19 would over-rev. slightly Just something you want to avoid as a new boater.
BornBlue82
OK so a 20/4 blade. What about 21/4 blade. Just curios to know what the difference is.
SkiDad
what did you end up getting ? Let us know your results :)
PS - i just picked up a used stainless prop - first one.
Bamaman1
I used to go thru an aluminum prop per year on my inboard outboards. When I switched to stainless, I got 10 years without a scratch--until the engine blew. In the long run, a stainless prop can be a great value.
Getting back to props: If you have a good prop shop around, go shopping there. His advice will be free if you buy from him, and he may allow you to return the prop if it's the wrong one for your boat.
I would think for general running, a 21 pitch 3 blade would be your best prop. I always had a 2" lower pitch prop I'd install for the day if pulling heavier skiers.
BornBlue82
I haven't pulled the trigger just yet. Still shopping around. I will post as soon as I get one.
BornBlue82
Thanks for the advice. I haven't looked for a prop shop around here but, that sounds like a great Idea. Thanks again.
