apollo5646
Thread starter- Joined
- Aug 16, 2009
- 28
Ok, I give, been searching the sight for a little info on how to wire up a sender. I found a couple diagrams but my question still is unanswered. The problem i get no reading from the fuel gauge always says E. As of right now i know that the gauge works i removed the send wire from the sender and if i touch it to a mounting screw on the sender it will peg to full, good right? but if i hook it back to the post nothing just E. I was wondering if perhaps the ground is not hooked up right. The ground wire comes to the tank and is attached to a stud on the tank about 10 inches from the sender. Looking at the diagrams i would think that ground should hook right to the sender, but being that the sender is screwed to the tank i would think that would provide the necessary electrical path to provide the ground or should their be a ground from the tank to the sender too. I'm a little puzzled please help.
