sensor pulse witch way clock\w or anti clock\w if fiywheel turns clock\wise
durban
i do not have a timeing light yet , iam trying to figure out on witch side from a 12o,clock position on my coil ,i know were the no1 piston is located on the coil , the timerbase tells me that, as inside underneath the sensors they are marked , now iam trying to position the sensor from a 12 o ,clock position in relation to the coil,once i know witch way the pulse goes clock wise or anti clock wise , then i can work it out just, need to know the pulse direction , because that will tell me whether iam advanced or retard, thanks
Daviet
Re: sensor pulse witch way clock\w or anti clock\w if fiywheel turns clock\wise
You might get more results if you post what you are working on, post the model number.
durban
the model is 1977 70hp evinrude 70773s i have fitted the timerbase & sensor to my 1970 60hp 60072d getting heaps of spark just need to find out if iam not recieveing spark after TDC , ,THATS WHY I NEED TO KNOW IF THE SENSOR RECIEVES THE PULSE FROM A CW OR CCW DIRECTION THEN I CAN WORK IT OUT FROM THERE , AS I HAVE NO TIMEING LIGHT .THANK YOU
durban
no worry i have worked it out ,by placein the sensor in a 12o clock position in relation to the coil , moving it clockwise, takes the motor to atdc, & anti clockwise to btdc, my 60hp 1970 conversion to 1977 70hp timerbase& sensor , was sucessfull , the motor starts even better , fistime
