Serial # Lookup please/Timing help
flyboycj84
Hi there.....working on my 97 searay with a 4.3.....a little confused on my distributor.....if a tb4 or 5.....there doesnt seem to be a knock sensor and the serv man 18 is a little confusing
Sn ok275908
Thank you!!!
Don S
Re: Serial # Lookup please
Go to Merc, https://webapps.brunswick.com/literature/literatureSearch.do type in your serial number, and you you will know for sure.
Service Literature for MERCRUISER TB5, W/PS, SGLPCEX, WORO, GEN+ 4.3LX ALPHA
Interpretation
Mercruiser (obviously), ThunderBolt 5 ignition, with power steering, single piece exhaust (manifold and elbow is one piece), Gen+ engine and a 4.3LX model with an Alpha outdrive.
achris
More fish than mountain goat
That's a 1997, 4.3LX, with Thunderbolt V... and some of the earlier TB-Vs didn't have knock sensors.
Chris.........
flyboycj84
Great.....thank you! Im away from motor at the moment, but have a pic on my iphone of dizzy and there is def no knock module.....but am i to time motor per the tb4 or 5 procedures?
Don S
You still time it to TB5 specs, knock sensor or not.
flyboycj84
Ok....ive also noticed that i have just the timing tab, and a line on balancer.....no sequential markings.....is that line already set to proper btdc? Or will I need an advance timing light?
Don S
The line is 0? or TDC Top Dead Center.
You need an advance timing light to set the proper degrees, or you can get a decal from Merc for it.
Don S
Just looked, and with your engine, Merc used the old pictures with the tin cover. They do that a lot :facepalm:
The part number for the decal is part number 37-864250
flyboycj84
Great! This motor is a long story but looks like a Sierra manifold gasket leak, rusted valves, no/low compression on 3cyls, heads off gettin a valvejob, manis/risers back to Sierra testing for possible warranty (if theyr good at least i know they were tested and i'll use merc gaskets this time). Just trying to get prepped to put it all back together being im DIY.
Thanks All!!!
flyboycj84
That decal goes on the balancer yes?
Don S
Re: Serial # Lookup please/Timing help
See if this helps.
flyboycj84
Oops.....accidentally typed and hit send. Meant to say "boy a picture is worth a thousand words!" That decal pic is just what i needed Don....thx!
