I have a 5.7 Mercruiser and it has developed quite a knocking sound. It puffs smoke through the carburetor and I though it was mis-firing so I changed all the plugs, wiring, rotor and cap. I seem to have water in the oil because the oil is a nice coffee color on the dip stick, as well as leak into the bilge with the same color. I tried marvel mystery oil hoping to lubricate and free up anything that was stuck but no good. I checked compression on all chambers and the are all within range 145-150.
The sound is definitely coming from the top as of the engine. I need to figure out if the rod it bent or broken or something else. I''m thinking of pulling off the cover and cranking it to see if I can see what is moving and what's not. Not sure how much oil will leak out though.
I then need to find out why the water is mixing with the oil and where it is leaking from. Riser, manifold...who knows. Fun, fun, fun.
Any and all help is greatly appreciated.
Joe
Joe
