- Joined
- May 16, 2009
- 9,452
Just for clarification, The engine serial number shows this engine to be carbureted.IF you have throttle body fuel injection, pumping the throttle does nothing.
Like mentioned above, the fuel you have now from June is fine to run for the remainder of the year.robinsbd said:I plan on using the boat through October, and I was wondering if adding a gallon or 2 of fresh gas would help boost the existing gas, or is there something else I should do? Thanks for all of your help.
Bear in mind that with todays fuel that has the potential of fuel separation, Overall, it's probably a better idea for you to keep your fuel tank closer to empty than full during your non use time. With that mentioned, 'If so desired by you, you could guesstimate the amount of fuel left in the tank and add some fuel stabilizer to the rest of the fuel to help protect the fuel for next years use. http://www.iboats.com/Boat-Parts-Ac...ched.1--session_id.654660195?q=Fuel stablizer
