nastyquedawg
Thread starter- Joined
- Dec 25, 2008
- 89
My boat was dieing to idle after runnig at WOT for about 20 secs. I installed a new fuel pump and ran it today. The boat ran for about 60 secs before dieing ro idle. So i figured it must be some trash in the carbs. Took it home. took the bowls off of the carbs and used compressed air to blow out the jets. I also change all of the fuel hose becuase I was not sure that the lines were ethanol resistant. Go everything back together, started the motor and it seems to idle higher than normal, so here are my questions.
1. Does the installation of a new fuel pump require me to adjust the idle?
2. What does this valve(item A in the picture) do on the primer solenoid?
3. Which way should it be turned. I cannot remember which way it was turned originally. When I turn it to the right it kills the motor, but do I need to turn it all the way to the left or some point in between?
4. There are 3 lines on the bottom of the primer solenoid. The two smaller lines(items B&C in the picture) are connected to the top of each carburetor and the bigger line is connected to the fuel line. I cleaned out the jets and bowls on the carburetor and forgot which line goes to which carburetor. Does it matter?
On the bottom of the motor in the front there is a vaccuum line that runs from the block to the left hand side of the air silencer assembly. The hose had a hole in it and i replaced it. Would this repair modifiy the idle speed?
Thanks
Thanks
