Hi again all. Meanwhile I disassembled a lot of parts, ordered a lot of gaskets (was expected to be cheaper
) and now I have some questions which answers I wasn t able to find them in the manual.
1 - When I lifted up the engine from the boot I found that piece of rubber which I have no idea where is from. Can you help me identify to order a new one ?
2 - What is that part that I marked with orange? I see is somehow damaged and want to order a new one
3 - What is that spot for? It was empty but probably there has to be fitted something...do you have any idea?
4 - On the cylinder head there is an wire which most probably is used for grounding (was grounded when i take the cover off). The issue is that I feel it like is almost broken, even if i treat it very gentle. Is there any way to replace it somehow ?
5 - On the lower unit there is a hose that came out and has a stopper on the free end. What is this for? Can I just remove it and put a stopper directly on the lower unit?
6 - How can I take off the water pump piece that is on the lower unit? (I ordered a new water pump complete in order to change it)
7 - On the engine block, on the carbs area, there is a hose which is split in 2 and go into the motor. I assume that is from an oil injector? Can I remove them and put some stoppers on the block ? I don t have any oil mixer and anyway will use directly mixed gasoline with the engine
8 - I removed also trim in order to clean it, paint it and replace seals and gaskets ...anyway the previous owner seems didn t change the anode when it should and beside that he painted it in red ......
The result is that on the trim cylinder there is something which looks like the material from the anode and is somehow melted/submitted on the cylinder ...any idea how can I remove that for clean up the cylinder and apply a new paint on it? (of course the anote will be changed with a new one)
Thanks a lot again for all your help. Very much appreciated
