services
warwickb
A newbie question, ---- workshop question-,
In a mariner parts diagram they show various types of lube types for various parts
eg drawings showing a diagram of a grease tube with various numbers stating the type on the end of the tube , where can i get a description and type of gooo .
wazza
warwickb
Re: services
guys, just found answer to my question ha, ha, at the top of parts catt , types of grease , sealants etc with merc patr numbers att, locktite 271 now goes under263 (thread locker)
still working on the rest.
wazza
CaptainKickback
Re: services
Glad you found your answer. But I'm not sure I see the connection of your thread's title and your question.
Sea ya...
Chris1956
Honorary Supreme Mariner
Re: services
Warwick, The manufacturers want you to buy some of their products, however, it approaches a scam on their part, IMHO.
What you need for lubrication is real simple. TCW-III two cycle oil for mixing (or oil injection) with the gasoline, Marine Gear Oil for mechanical shift motors for your gearcase, and some multipurpose grease for everything else. Some fittings (not many) can use a threadlocker. Merc makes a special lube 101 which is a bit superior to regular grease for steering cable ends. The rest is snake oil. I use Marine (cartridge) Grease, TCW-III and Gear Oil from Wallyworld. Some Permatex #2 and some blue locktite are handy to have around as well.
