FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have not looked at the carb yet I just purchased the boat...sorry<br /><br />So I geuss what your saying is it's not just a matter of turning the idle screw down a little?<br /><br />Skipper
It could be that simple, but you may have to adjust the air/gas a little. You should also adjust the idle in the water, in gear. Was the idle in the water in gear 1000 rpm's?
Im sorry I don't have the exact numbers for you I appriaciate the quick responses I'm pretty sure it does idle in and out of gear at around 1000 I think its a little lower in gear maybe 900 or so<br /><br />Skipper
So I should do it in the water in gear then turn down the idle screw slowly?<br /><br />How do I know if I have to play with the air mixture screw?<br /><br />Skipper
Turn it down a little and then turn the air adj screw back and forth a small amount and see if it reaches a higher, smoother rpm. Then you can drop the idle screw a little more. It should be done with a gauge but I have always just used my ear. If you are going to try it on your own keep track how far you have turned it in or out so you will be able to set it back if you make a mistake
Where is the air mixture screw will it be close to the idle screw?<br />Can I do it in the driveway with the muffs on it will work the same right?<br />Will I have to turn the idle screw quite a bit or very little?<br /><br />Thanks<br />Skipper
I believe port side of the motor on the side of the carb. Give the idle screw a quarter turn out and let it run 30 seconds or so. If it needs more go another quarter
Thanks Tommays!!<br /><br />When I put it in gear it does clunk pretty good I will attempt it tonight<br /><br />Thanks for the help!!<br /><br />Skipper
I attempted setting the idle and it almost stalled out so I turned it up a little and it was idling at around 700 which I was happy with when I took the boat out the next day it seems like it is idling at 900 again any ideas?<br /><br />Thanks for any help<br /><br />Skipper
i have found that the controls dont return the carb to idle stop that well <br /><br />there should be a barrel on the cable (mines on the valve cover) that will allow you to remove it and give it a few turns so it pulls to the stop the same every time<br /><br />just a littel bit you dont want it mashing the stop just geting there <br /><br />tommays
Sorry for the delay guys!<br /><br />I have a 97 Bombardier Celebrity 180 so I am assuming it's a 97 Motor as well<br /><br />Tommays so what you mean is I am going to tighten the cable a little so it puts a little more back pressure right?<br /><br />Thanks Gents!!
What you need to do is disconnect the throttle cable from the carb at (D), adjust the idle speed screw to the proper rpm, then reattach the cable. You will probably have to adjust the barrel (C) so the cable just holds a slight amount of preload on the carb to hold it in the idle position.<br /><br />
Thanks Don<br /><br />I will print this and try it when I get home! <br />Earlier someone mentioned an air mixture screw do you know anything about that?<br />Much appreciated<br /><br />Keith
Don?<br /><br />Do you know anything about the air mixture screw?<br /><br />Do I have to do this in the water idling or can I do it with the muffs on in the driveway?<br /><br />Thanks
