setting on tacho switch
Hi all,
I'm busy with an original Yamaha digital trim/tacho switch on my 85hp 1991 yamaha outboard.
I have everything working, but don't know how to set the switch on the back of the gauge.
If I switch it while motor is running I would say "no 12" is the right one, but I am not sure.
The boat (and motor) are not in the water right now so i have to do the rpm measuring by cooling it with the hose..
Anyone there who knows more about this one??
Re: setting on tacho switch
Thanx rodbolt.
It's wat I thought, but when you tell me I'am sure....
Bought the gauge from a guy with a 60 hp Yamaha. He had it working well on 6 pole he said. His Yamaha was also a 3 cyl. Do you know why the setting is different?
Greetings Robert
rodbolt
because the 60 used a 6 pole altenater and the 90 uses a 12 pole altenator. other than that the tach settings are the same.
rodbolt
I did not want to just say cause the manual says to :):)
