Setting the jet screw
mick97
I just got a new head gasket on,and all is well :)
I did mess with the jet screw a little when i was trying to figure out what was wrong before.
I know its like 1 1/2 turns out its suppose to be.If I go to 2 full turns out,that uses more gas correct?
No biggy.But was just wondering if it will give me some more power to plain out quicker..Or at least a little more horse power lol.
Thanks,
Mick
Jiggz
More turns out will give you a richer idle causing plug fouling.
jerryjerry05
The air screw is for idle operation only.
​Does nothing for top end.
It allows the air/fuel mix to be set right so the idle is smooth.
Just guessing what motor you have ??
They can be set differently on different motors??
You can add a signature at the bottom of your posts and include the boat info and a pic if wanted.
That way people can tell what you have ay all times,
