bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
after posting about motor heights on another thread, I went out to really take a look at my set up..
I mounted a 10"set back hydraulic jack on my 20 ft mod V. then mounted a 1995 115 hp 2 stroke on that.
the motor has 4 sets of holes and the jack has two sets of holes on BOTH sides of the jack..
well i used the absolute heighest combo I could and it still doesnt get my cav plate above the bottom of the hull.....
AS THE TRIM PIN IS SET CURRENTLY
when trimmed all the way in...to pin setting hole #1 the cav plate goes way past parrallel with the bottom of the hull...and thus is actually at almost a 10 degree angle down from parrallel..
I have been using the boat all winter like that...I am not experiencing any negative effects that I KNOW OF!!
so i trimmed the motor out today and eventually when the cavitation plate IS PARRALLEL with the hull......it is dead even with the bottom of the hull!!!
but the motor looks like it is trimmed out maybe to PIN HOLE # 3, or #4
(there are 6 pin holes, set at 2 rows of three each one row above the other...)
SHOULD I set a pin at this spot that will not allow my trim to force the cav plate past parrallel???
I do not have issue with keeping the nose down...
mainly because i just have always trimmed IN until she stops..
some times for max speed Ill trim out and pick up maybe 3-4 MPH..
Trim is really only important to me under power, when :
1) the waves a rough and I want to get the bow way up, to keep them from breaking over it....and obviously i am not going that fast
2) when i am going as fast as i can on flat calm water..
all other times I am just planing, and or the water is too rough to go full speed.
here is a photo of the prvious motor I had mounted on the jack..a 90 hp ocean pro, but it is the exact same motor as the 115 ocean runner I currently have...these dont show how I mounted my current motor, but they show the holes for the trim pin.
thanks
bob
thanks
bob
