Re: Setting up a well
Stick with the least amount of air to activate your pressure switch. When the tanks go bad, it is usually the bladder that seperates the air and water. More air on the bladder will cause it to fatigue sooner. <br /><br />Also, you may have to add a little air after a month or two of use as the bladder stretches and increases the air volume required in the tank.<br /><br />Also, Im not sure how far you are pumping but if the tank is outside or in a basement, you may want to consider putting a check valve in line before your main water supply.
