I recently read an article about setting up your drag. The article simply stated that you should rig your pole using the line and knots that you're going to use for that type of fishing then put the hook into something, pay out about 20 fett of line, set your drag lite and then start putting tension on the line straight out. Start tighening the drag until something in setup fails.
I tried this and 90% of the time the knots failed first which is what I expected. That's fine, with mono or FC I know that no matter how careful I am they are always going to be the weakest link. So this method does work pretty well but I think it covers only a limited amount of situations.
What do you do when you use your drag to let a fish run and tire? I guess the only solution would be to setup your reels drag so that the maximum amount you could ever apply would be just below the breaking point of the weakest link in your rig, the knots.
Holly Mackeral Andy, you'd need to do that everytime you changed line or rigs!!!!
So, what I have come acustomed to doing, is to leave the drag at a moderate level and then working it while I'm playing the fish. On my bait casters I'll use my thumb and the Star drag to fine tune it and on my spinning reels I'll palm the spool. You might try it if you're not already doing it, it's much easier than what some line manufacturers recommend (the article was from SunLine).
