- Joined
- Apr 17, 2002
- 71,539
Re: Severe Torque Steer To Port
Ayuh,.... The tab pivots in it's center, 'n those pictures explain the Right way to set it....
I have a question.....Regarding the pictures from GKing I can see that if your tab adjustment is at the rear of the tab then what is shown and what you say are true, but if the tab adjustment is at the front of the tab would you not adjust it to the opposit to counter the pull? I don't know that's why I'm asking. I set mine for neutral steer and it didn't change the starboard pull I was experiencing. I have radjusted it to oppose the original set up but was unable to test drive it so see what if any difference there may be. I don't have a power trim so it's kinda tough changing plane while running across the water. My engine is a Force 85HP the boat is a 1989 Spectrum aluminum hull sport/fisher. I tried to balance the weight evenly throughout the boat but that has no effect. This motor really gets this thing up on a suitable plane very fast but it pulls like crazy getting there. Once on plane if I let up on the steering wheel it just swings the boat to the right and I mean right now. Scarey stuff.....HELP!!!!!!!!!!!!!!!!!!!!!
