crackedglass
- Joined
- Jan 4, 2009
- 207
I'm not one to go looking for big projects but I found a boat today that other than a broken transom, looks like new. It's a 1962 MFG, its been in storage for many years after the transom broke.
It's got an older V4 50 hp on it, which probably would run with a little tlc, but the transom has broken and torn about 6" down on both sides of the motor brackets. The inner skin is pulled through and broken, the top of the transom is completely hollow, no sign of any wood left. The motor was only clamped, no bolt holes. The rest of the boat looks as if it just left the showroom, it still has it's original seats, the gel coat looks new, and the yellow original Gator trailer is rust free.
I can't say how long it's been sitting where it's at, but the last registration sticker is fron 1966. The dash is untouched, no holes, nothing changed from day one.
My concern is that the outer skin is so damaged. The inner skin is no big deal, it would most likely get cut away and tossed when redoing the transom anyway. But the outer skin has been compromised. Can this ever be 100% again? Is it worth the attempt? I know I could probably patch up the outer skin and add a metal reinforcement plate or do a Sea Cast pour but the expense of Seacast is not really in my budget right now. The wood core is easy, I've done one of these boats already, and I'll most likely run a much lighter motor, sending the oversized 50 HP to some collector.
The boat is super clean, even the original plexiglass windshield is mint. The original seats are covered in burlap sacks for storage, entire boat was shrink wrapped and the trailer put on stands up on a rack in a warehouse.
Its got a clear title, for both the boat and trailer, the trailer itself is super cool, just finding an old trailer with the styled fenders in mint shape is cool.
I doubt I'd ever find another one in this shape cosmetically, I can no doubt hide the repairs and make it strong enough to last. I'm just not positive that a glass repair where the transom has to remain at a somewhat uniform thickness will hold up. I can't lay up layers or feather it out too far in an area where the motor must lay flat to the transom, and doing the patch to the outer skin to the inside of the transom cavity, will no doubt affect the fit of the new plywood core. (If doing this with SeaCast, then there would be little concern). My fiberglass experience is moderate at best, I've done two transom replacements and two sole replacements and some light patching but nothing where thickness would affect either fit or structure.
Any suggestions? Is Seacast this boats only hope?
I don't have any pics, it's not mine yet, I'm still debating it. But I do like the boat. I believe it's a Niagara model.
