I have seen it posted in a number of threads:
- Never run trolling motor out of the water. It will destroy shaft seals.
- Use STP Stop Leak (or other) to recondition the seals.
Until recently, never seen this info posted on iBoats or other places. At 1st, didn't give it much attention, but after numerous threads, and no question/discussion about it, began to wonder.
I have run all my trolling motors out of the water, at numerous times, checking things out. While I haven't run them for extended times (don't know why I would), never thought there was emminent danger of destroying the seals. Given there is no load on the prop, they spin right up, and there is no heat to speak of. I even went and downloaded the very latest user manual for one, and walked through all the recommendations, warnings, etc. Nothing about running out of water. Is this something that was a problem with very early designs, and not to worry with any modern ones? In other words, people should not be worried about running the motor out of the water for testing. Or have I just been extremely lucky?
I have never used any reconditioning on the seals, and again nothing in the manuals. Does anyone else use STP or other conditioner on seals? It sounds like an easy thing to do, but not even sure the seals are made of rubber. I thought they were more a oil based product. Is the Stop Leak fixing something else? In fact, the way I thought Stop Leak worked in a radiator system, wouldn't seem like it be the best for direct apply. ???
