Shaft stuck in hole !!!
marty_scher
I know what you are thinking, and this is not it :) <br /><br />My removable pedestal seats have a shaft that sticks in a hole on the base and uses a button latch.<br /><br />Although the boat is new, removing these seats requires a move that can only be likened to a drunken Scot trying to lift a 200# cannonball off of the ground :eek: <br /><br />It would like to find something to lubricate these mounts (which use plastice sleeves) without becoming gummy and making it worse.<br /><br />Any ideas are appreciated. <br /><br />No offense to the fine Scots, but don't they like to drink and throw huge objects around :)
derwood
Re: Shaft stuck in hole !!!
Mabey some powderd Graphite might help.<br /><br />You can get it at a hardware store.<br /><br />Let us know if you try it and it works.<br /><br />Derwood.
Bob_VT
It's time to plan on a rebuild this coming winter season. That used to happen on a bass boat I fished out of and yes it is frustrating.<br /><br />Solution: Turn the shafts down about 1/16" in a metal lathe. Cure the problem we had.<br /><br />Bob
fishingbear5
Silicone works great for pedistal seats. Does not gum up either. Tight lines.
sloopy
bag pipes, bear, and heavy objects don't mix !
martyscher
Since they have plastic sleeves in the base, I simply sprayed in some AmorAll.<br /><br />They pull right out now.<br /><br />Thanks everyone.
