Shaving block
rickdog67emtp
Is there any way to shave a block for straightness? I have a crossflow V6
Dhadley
Re: Shaving block
There is a way but you better not cut much. How much are you going to cut?
rickdog67emtp
Re: Shaving block
prolly a few thousandths. It appears to be slightly warped from a blown head gasket at the bottom
Dhadley
Re: Shaving block
You mean .003 - .004? As long as its never been cut before that will be fine. Once you start putting it all back together you can check to see if the pistons are going to hit the heads.
Dhadley
Re: Shaving block
When the motors apart a machine shop will jig it up in either a broach or a mill. Once its centered, level and even to the crank centerline they'll cut it. Just make sure you clean it really good before reassembly.
