I didn't tighten the flywheel nut while working on this motor and sheared the key. The flywheel keyway was slightly damaged (see pics). It's widened out at the bottom and has a lump on the bottom face. The cam was cracked too. The crankshaft keyway is ok. I can get a cheap used cam. I read I can lap the shaft and flywheel with valve grinding compound, but if I do that for the lump on bottom wouldn't it grind of the word "top" on the cam and make setting points difficult? I could buy a used flywheel but don't want to spend $50 on that when I haven't got this motor running yet to confirm it'll actually run well. Any advice?
