shell nitrogen enriched fuel causing problems?
talies13
I have used shell nitrogen enriched fuel in my 5.0 mercruiser and my 3.0 both are alpha ones. After using these fuels I have had problems starting both engines. Is this coincidence or should i stay away from that fuel.
Don S
Re: shell nitrogen enriched fuel causing problems?
Change fuels and see if the problem goes away. Then you will know for sure if it's your problem or or not.
