ihaveabrownboat
Thread starter- Joined
- Aug 24, 2012
- 88
Not sure if I have one problem or two but have two separate things going on. Advice from those familiar once again offered in terms that someone who isn't might understand is appreciated; please. Here's what's going on:
1980 Mercruiser 165. It shifts in to forward and reverse on muffs. When on muffs it also goes from gear to neutral to gear without dieing.
In the water it will go in forward gear but won't go in reverse. This is both whether going from neutral and never having been in forward or if you've been moving forward and are attempting to slow down. It will never go in to neutral when the boat is in the lake.
When in the lake the shift interrupt circuit also engages and kills the engine when coming out of gear. It's not dieing at idle. Can pull the lever back far enough to let the engine idle with the lever still just barely short of neutral and the engine idles fine. Pull the lever back that tiny bit more to find neutral and the engine is killed. Does not do this on muffs but does it everytime on the lake.
I'd asked about part of this before but hadn't asked about the two issues together. So before tearing in to things wanted to circle the wagons once more and make sure all of what's going on is considered. Is this likely one problem manifesting itself in two areas or are there two separate things going on?
Thanks.
Thanks.
