shift boot clamp?
brunolund
how tight should the crimp pclamp be on alpha one gen 2? is the cable supposed to be able to slide in and out when the outdrive goes up and down?, or is this the reason for the bellows?
Fishermark
Re: shift boot clamp?
Adjust the belows so there is an accordian effect when it lifts and lowers. Forget the metal clamp supplied - use a good quality zip tie instead. (It doesn't rust).
JustJason
use a marine fuel line zip tie with the curved end
