Re: shift cable adj., 1 drive
This really is not that complicated.....
Put the helm in forward.....
Push the unhooked cable end in & turn the prop ccw to lock....
Adjust the barrel to 6" from center of eye to center of eye (cable end).....
My guess is that they will fit right over the studs.....
From the sound of it you are OK, Zig.....
Ya might have to fiddle with it a little, like Don says, but you will be close....
I just finished this on my dad's boat a few weeks ago. It was the first time I had installed and adjusted a cable set up like his - and I think like yours. The one with the reverse lock out switch that the cables hook onto - correct?
Anyway, it's not as difficult as it sounds. Haut has it correct. The only thing to add is after putting the helm in forward, you then "dismount" the control cable from where it is attached. After adjusting the shift cable to the six inch setting, and ensuring that the unit is in forward, put it on and don't change that setting again. You then match the control cable so it fits onto the posts. It is that simple.
Some say to match it up, then turn the barrel an additional 4 turns.... I think the more important aspect is to try and understand what happens to the cables when you shift so you will know which way to adjust if either reverse or forward is giving you a problem.
The real key is to only adjust the control cable - not the lower shift cable.
See? Easy!
