81 Checkmate
Thread starter- Joined
- Jul 20, 2010
- 1,360
I have one Question on Shift cable adjustment. I replaced the shift cable last night. Triple check Alignment of fork to roller and lower shift shaft to bell shaft. Everything is all lined up and the drive unit went on very smothley no beating with logs or soft hammers. Check F anf R Lock/ratchet with cable by hand all good. Adjusted end at shift plate like artical in Mercrusier post. Shift is nice and smooth both directions F and R. When i do the final check with useing shifter in forward it works great turn prop to left and locks in and turn to right and it ratchets like my other boat. When i put into reverse the props locks to the right then when you ratchet it turns freely but it is a little stiffer and when you look at the shift plate and cable end on the shift plate it moves back and forth about 3/8 of an inch when you try to ratchet it to the left. This doesnt seem right to me but maybe it is. QUESTION IS can this all be in the adjustment or will i have to pull the drive back off. Realy doesent madder witch one becouse the drive install went so smooth. Any Any Help today would greatly be apreciated. Thanks
