eavega
Thread starter- Joined
- Apr 29, 2008
- 1,377
Gaaaah! My internet Fu has failed me. So, went out today on my 1988 Stingray (3.0L Mercruiser/Alpha 1) to get some lake time/learn to wakeboard. Was towing the kids on the tube when one fell off, so I throttle back, into neutral, then try to reverse. No reverse. Heck, no neutral! I had just paid a mechanic to replace the lower shift cable, as I had been having trouble finding neutral last season. I open the engine compartment to see if there is something obvious (like the mechanic forgot to reattach something), and no. the new lower cable is there, everything is attached as expected. I have my wife throw the shift from forward to neutral, to reverse, and I don't see the plate with the shift interrupt moving! I look behind the side panel where the remote is mounted, and I see the cable connecting into the remote has come apart. That is to say, the outside of the cable has come apart, there is still a wire running through it. The casing is all open and frayed. I'll assume that is what is now busted on the boat. I need to replace the shift cable from the remote control to the shift plate. Problem is that I can't find a diagram that shows this cable, or a procedure for replacing this cable, either in the manuals (I have manual 10 for the engine, and manual 6 for the outdrive) or onlline. Can someone point me in the right direction here? Every internet search I do returns back instructions and parts for replacing the lower shift cable, not the cable from the remote to the shift plate (which I am making the assumption is called the "upper shift cable"?). I need to know the part I need to order, and a procedure for installation/proper adjustment. Thanks in advance.
Rgds
Eric
Rgds
Eric
