If there was corrosion in that area, your upper shift shaft seal may be shot and allowing water to get into that area. I went through that with an 888 drive - freshwater only but there was a ton of white corrosion in the shift slide area - it was evident that water was getting in there and it could be traced to the upper shift shaft seal.
