Fiat4Fun
- Joined
- Sep 14, 2009
- 223
So, I thought I would start a new thread, since I am second guessing myself. I have 1986 Alpha One, Gen 1, that I replace the water pump in the outdrive and all the bellows, along with the lower shift cable. I have used the manual and the great wealth of information on the forum. But I can't seem to get the cable working correctly. Here is where I am at.
I put it together the first time, could not get it in reverse. So I took the outdrive on and off and also adjusted the cables a few times. I even split the drive to check the shoe was not off by one tooth. Could not get it right. So yesterday, I took the outdrive off and I can move the outdrive in and out of gear, no problem, with the shoe facing forward in forward gear.
When I reassemble the out drive, and push the lower shift cable in to get my measurement of 6". the outdrive is no longer if forward gear, the prop shaft is locked in both directions. It seems like the shift slide either disengages from the roller? Almost like the cable is too long. If I put the outdrive on, I can not shift the drive by moving the cable? Seems like I should be able to do that? With the drive off, the cable moves the shift slide without any issues.
I thought if the drive was in forward, and the shoes line up, I should not be able to move the cable inward, since I thought the drive is in forward gear.
I also read that when attaching the rod onto the new cable at the motor, I should screw it in all the way, then back out two turns, then put the lock nut on. I have not tried that..........
Any advice is appreciated, since I feel I am chasing my tail a bit.........
Thanks
Thanks
