Shift cable realignment??... 73 Merc 1150
AntelopeWI
Well, I finally got my 1150 running. What a good feeling to hear it fire up.
Seem to have a small shifting issue. I suspect that the cable just needs to be adjusted. My Seloc manual does not desctibe this very good. I'm hoping I can get a little insight on here.
Here is the deal.
If control box is in neutral detent, the prop spins freely but has a slight click to it as if it is just on the edge of engaging. You can feel the click with your hand as you spin the prop too. When started in this position, the prop spins in reverse ever so slowly.
If I pull the throttle lever back about a half inch, the prop spins freely with no clicking and it spins smooth in the hand. At this point, it feels like the throttle lever has just rose up the neutral detent, and is kinda sitting on the edge of it just before it clicks over to reverse. It is far enough, however, that the engine won't start in that position. Once I start it, and move the lever back to that spot, the prop does not spin. It seems to shift into forward alright. I think it shifts into reverse alright, but I have to pull the lever farther into reverse to get it to engage than I have to push it towards the bow to get it into forward gear.
Anyway, seems to me the cable needs to be adjusted. Sound that way to you all?
Would like some pointers on how to go about doing that.
thanks,
john
CV16
Re: Shift cable realignment??... 73 Merc 1150
There should be a brass barrel where the cable attaches to your motor. Just adjust that one way or the other and you should be good. It's an easy adjustment.
Chris1956
John, Disconnect the barrel nut from the clamp (control in neutral). Wiggle the shift slider a bit until it settles into the motor's neutral detent. Now adjust the barrel nut to fit the clamp.
SKGrice
Make sure that you have the cable disconnected at the motor. Shift the control and motor into neutral by hand. make sure they are both in the neutral position.
Always adjust the cable to the motor never the motor to the cable and you will be fine.
