Shift cables at control handle
smithrock
On my Alpha 1, when I pull on the cables from the backside of the control handle there is a little play in them, they feel a little loose. Should they be this way, or do I need to take off the handle and try to tighten them?
Re: Shift cables at control handle
Ayuh,...
Are you chasing a Shifting or Throttle Issue,..??
If so,...
Explain the Issue,+ then your question might have an Answer...
smithrock
shifting issue. I want to take it apart and see if there is an adjustment or what. i'll wait till I hear back from you before doing anything unecessary
Any ideas?
hard-3
Generally there is no adjustment on the control module. there is and adjustment proceedure to follow to get it adjusted to the lower cable. do a search on cable adjustment in the forum and you will find a link to learn how to do it. As a rule, the cables are not really adjusted . they are set to a length as determined with a gauge and matched to the lower unit cable. if the cables wear beyond spec's they have to be replaced. Most wear is in lower unit shift cable for some reason. as you will find in the search results this is a very common problem.
smithrock
Yeah, thanks. I am aware of the lower shift cable adjustment. Just trying to figure out every possible thing before I go ahead and replace the cable
Ayuh,.... Save yourself some Extra work,+ just Change out the Lower Shift Cable.....
There's probably Nothing wrong with your Control, or it's cables...
Don S
On my Alpha 1 .............. shifting issue. I want to take it apart and see if there is an adjustment or what
Basically, that is all the info we have about your problem. Why don't you just post what year this Alpha I is (people have called 1 drives and gen II drives "alpha I" many times and were wrong) then post exactly what type "Shifting Issue" you have. It may be a simple answere to a question never asked.
smithrock
It's a 1985. The shifting issue is the shift interruptor switch cuts out the engine when going into reverse. I had it working last summer for a while, but it's back doing it again. So I wanted to see if there could be anything else I could do before changing out the lower shift cable.
also, would low gear oil have anything to do with the shifting problem?
Don S
Nothing in the helm control or the shift cable between the helm and the engine could cause that.
You need a lower shift cable, or the shift shaft is corroded and stiff in the bellhousing, or you have a drive problem. Move your troubleshooting to those areas, not the control box.
Ayuh,....
Low Gear Oil will cause All Sorts of Problem,.....
But,...
I still think your root problem is the Lower Shift Cable.......
Don S
Gotcha :p:D
smithrock
Ok. The cable does move freely back and forth, so thats why I was thinking adjustment.
I don't know if my gear oil is low, I'll check it shortly. Do I just unscrew the vent screw and see if any spills out?
Don S
Here is a link to the oem service manual. Go to section 2A and read how to adjust the cables properly.
Ayuh,.....
Ya forgot the Link,......
And,....
How do you put it,..??..?? "Gotcha :p:D".....
smithrock
Got the manual, and followed it correctly. Still have the problem.
Gear oil- does it have to be marine? Or can i use automotive? If so, what weight?
Thanks guys for your help!
Ayuh,.....
I run Mobil 1, in 75W-90.....
About Any quality Gear Oil in 90W will work.....
smithrock
Okay, thanks. I just checked it and it seems low (nothing draining out the vent screw) What I did find felt thick and a little gunky
Don S
Ayuh,.....
And,....
:redface: #$@#$@#, that couldn't have happened at a worse time!
Ayuh,.....
You should be Checking the Bottom Drain Plug,...
That's the 1 that'll show any Water, or Metal Filings.....
Ayuh,....
And I captured it in a Quote,...
Just in case you were Editing while I was Peckin',.......
You up to 10 fingers yet,..?? I see you got the stiches out........;)
