Mercury 75 HP ELPTO 1995 SN: OG177054. LU is removed.
The shift cam has moved and I'm having difficulty getting it back in position. I put the shift rod in and I need to rotate it a long way to find neutral at the end of travel. When I turn it the other way it goes into FWD and stays that way until I hit neutral at the end of travel in the opposite direction. Reverse is never there. Is there a way to verify the placement of the shift cam by referencing the location of the part number on the cam?
