mercuiser 470/170<br />when i put it in forward gear motor dies.put it in revers its ok. neutral ok,if i full around with the throttle for a little while, then its ok,the boat runs fine and idles fine,im think that it is in the remote control handle or the shift cut out switch. can i bypass it ,and what does it do,is it there to make sure it is in neutral before you start it
