Shift: Electric / Mechanic hydro assist/ Mechanic /
rodbolt
dude<br /> ya gotta learn to look at the paragraph/chapter headings or we are all gonna be confused :) :)
mrbarth
Hi<br /><br />How can I find out which type of gear shift I have <br />Electric, Mechanic hydraulic assist or pure mechanic on my 1991 90 HP OMC/Johnson motor to folloe it up in my Seloc manual ?<br /><br />Thanks a lot.
mrbarth
Re: Shift: Electric / Mechanic hydro assist/ Mechanic /
Yes captain Sir, you are right.<br /><br />looks as if I have the same problem with marine<br />literature as the rest of the world with computer literature, that I always find peanuts to follow.<br /><br />Problem for me is that this manual is THICK, I had just 3 weeks to read it AND I have to translate it into another language. <br /><br />And sometimes, you just get desperate. e.x to the Seloc manual, the PTT manual release valve should be on starboard, mine is on port.<br /><br />Or am I again on a wrong chapter ??? or looking from the wrong side onto my boat. :) <br /><br />And as you saw on my last post (shift in forward) I afterall found the right chapter, just wanted to make sure.<br /><br /><br />(And how can a captian get confused ;)
WillyBWright
No need to look it up. It's mechanical. Electrics were around in the 60s and the hydroelectric was in the late 60's to early 70s. They've been mechanical on all models ever since.
mrbarth
Now if I could understand the last sentence :) <br /><br />TJ90TLEI E.<br /><br />And may be I get the sides wrong ?<br />starboard (steuerbord) in the states the right side of the boat if looking from back to front ??? ;) <br /><br />forgot the thing about which thumb shows starboard
mrbarth
Thanks oBJ,<br />does not work in German Steuerbord and Backbord,<br />but the Steuer has an "R" in it therefor RECHTS.<br /><br />So my valve is LINKS :)
mrbarth
Now before the captain lets me walk the plank,<br /><br />here is the picture of the valve (the only one I have btw) <br /><br />
<br /><br />and just to be sure, the side of the motor.<br /><br />
<br /><br />thats port I hope ????????????????????????
mrbarth
Thank you guy, don't tell my wife I was right :) <br />What a relief, I knew which side was starboard.<br /><br />That still makes the Seloc wrong as they are talking avout 2 cylinders an with the PTT and still say teh valve is starboard.<br /><br />So I thing I'm a little bit excused if I doubted the <br />shift etc. chapters and asked which one I have :) <br /><br />Thanks for your help again.<br /><br />I would have not been able to get the engine this far without this forum.
rodbolt
hello<br /> unless the hanging chads are dimminishing my vision your 91 90 should still have the manual release on the stbd side. but no telling anymore. post your engine model number.<br /> dont sweat the small details and its all small short of dying :) :) .
OBJ
Left/Port....four letters each.<br /><br />Starboard/Right.....not a match.<br /><br />Ya' know, you should break down and get a OEM service manual for that engine. Would save you a lot of time in figuring out what's what in that generic manual. Check the sites below.<br /><br /> http://www.marineengine.com/manuals/evinrude/order_pre-1980.html <br /><br /> http://ww3.kencook.com/evinrudejohnsonmanuals/ <br /><br />Give it some thought boats. :)
OBJ
Yep. Port side. That's the manual release. You have the newer two cylinder diesign. rodbolt was thinking three cylinder like I was.
