nola mike
- Joined
- Apr 22, 2009
- 5,524
Alpha 1 gen 1. Changed impeller (left upper half of drive attached). Now
the shift fork on the transom assembly slips off of the gear lever on the
outdrive. I figured I didn't have everything aligned correctly during
reassembly and bent/broke something, but I split the case and removed the
drive--everything seems straight, and I don't even see how something COULD
bend. Only thing might be the shift shaft lying too low on the drive
maybe? There's a lip that lies flush with the drive housing; at this point
it slips. If I pull the shaft up a bit, it works fine...pics attached
