wellcraft-classic210
Thread starter- Joined
- Sep 22, 2010
- 839
Hi
I have had a problem for some time that If i adjust so the shift interrupt to behave as expected coming out of forward Then when coming out of reverse I must give a really crisp shift and sometime go towards drive to get the sift interrupt to work.
As I have tried various adjustments on the arm and cables I can feel it getting harder to shift at the throttle control but still not getting good result -- stalled 1 time etc
I have checked the switch activation point and its less that 1/8 using a drill but as a gauge and end play in cables seems to be in spec per the Achris video as well.
I was looking at the roller switch activation with a DVM and noticed a couple of things that I wonder are to be expected.
The Up activation differs from the down activation distance as it seems the roller arm bends more when it moves up.
The switch does seem to be fairly stiff to activate even after using silicone spray and cleaning the plunger
My questions are as follows.
Is this normal or is my switch activation pressure part of the issue ( dried up lubricant inside or other ?? )
Is the upgrade a better design and should I consider that.
