Shift Interrupt
joey nathan
Hi All
Trying to help son-in-law with boat issue. '97 Mercruiser 3.0 LX 135HP and we need the part number for the little microswitch mounted on top of the valve cover. Currently is it jumpered out to run so pretty sure switch has failed.
Engine is OK 1478989 serial number...
Thanks alot,
Jon
Bt Doctur
Re: Shift Interrupt
does work, scroll down to the engine 3.0LX GM 181I-LX 1996-1997
0F604000_OK999999, there are 2 types
SHIFT BRACKET (USE WITH STAMPED STEEL ROCKER COVER).pdf
SHIFT COMPONENTS (USE WITH CAST ALUMINUM ROCKER COVER).pdf
