greenwell001
- Joined
- Aug 5, 2009
- 121
hey guys
went word for word buy the manual and with a lot of help from this forum i got my impeller changed out and the drive back on.....started it up (in the driveway) and the alpha 1 gen 2 was throwing out the water good... mission acomplished.....well then i want to check and see if i had forward and reverse and as soon as i started to shift into forward i heard the gears smashing together and relized that the shift interupt didnt happen so i imediately put it back in neutral......this is the first time the boat had been shifted this season and the cables most likely need changing....my question is did i do something wrong putting the drive back on (yes i had it in forward) or do you think it is the cable not engaging the interupt or do the interupt switches go bad very often....last question is did i do any damage to the gears
