shift issue and running with some noise from lower unit gear
Should never start or run that high, that was the U joints banging around
liusigou
Today I push a lot of greese through this hole, but I did not any greese. Was the greese push into gimbal bearing?
Nope,.... It'll pile up on the tiller arm, inside the boat,.....
The gimbal bearing fitting is 'bout 1/2 way down the starboard side,....
liusigou
Today I found the wire of the part is broken. Should I fix it? But it work as even the wire is broken
liusigou
It is difficult to pull it out. How can I fix it?
flashback
Trim sensor or limitor, it's a pain to replace and isn't worth fixing but you can try...
nola mike
Help me please
Yes, it's difficult to repair. No, you don't need it. Seems like you have enough issues to take care of, I'd leave that one until you do your bellows. I haven't had a trim gauge or limit switch in years
liusigou
I have two mercruiser, I have given up the one that the third cylinder compressure is low. Now I continue working on the new boat which cylinders are good in compressures.
Current the new boat does not have the issue of bellows.
I will leave it if it is not necessary.
Thank you
