1995 Suzuki DT40.
Had to pull the shift linkage out of lower unit when I inspected the gears. Turned the unit upside down and a 1/4 ball fell out. I see a notch on the back side of the linkage, looks like this ball goes there.
Is this right? If so, how do I get it back in? I was unable to get the pinion gear off the drive shaft, and therefor could not get the forward gear out--so if anyone can tell me how to get the pinion gear unstuck from the drive shaft, that may enable me to access the area where the ball goes. But I may be way off here.
Thank you in advance.
