I'm in the process of changing my gimbal housing, transom plate, and engine. The boat is a '74 powered (well not yet) by a 250 inline 6 w/ alpha gen 1. I'm replacing the old pre-alpha/MR housing for a gen 1. So far I have the housing in and sealed, but am stuck when it comes to the shift and switch assembly. The old inner transom plate had the trim accuator, switch, and shift plate mounted directly to it. The newer style does not have mounting holes to bolt any of these to. I have all of the old parts and was hoping to still use them as they all still worked. Is there something I can modify to use them, or do I have to buy all new parts. If new parts are needed, what exactly do I need to get.
Thanks in advance.
Will
Thanks in advance.
Will
