Shift position problem
john530
I recently installed a motor on my boat and hooked up all the controls. I went and launched it and when i went to put in reverse it went forward and the same the other way. When i push the shifter forward it goes in reverse. So I was thinking of just shifting the motor into forward and then disconnecting the cable and moving the shifter forward and then hooking the cables back up. I don't know if its that simple though. Any help is much appreciated.
Monte1961
Re: Shift position problem
Does this engine and controls mount as the original did?
john530
Yeah pretty much the same. I had mercury but now i have an evinrude 48.
Mercury controls are not compatable with Johnson motors. If the control is universal, it might be reconfigurable.
