Always something to fix on a 1972 140 HP Mercruiser Type I drive. Was shifting just fine now when I shift back to neutral from forward or reverse the out drive does not go into neutral. Shift from forward to neutral then the control lever fills like it is in a bind when trying to shift on to reverse. Rock the handle back and forth (barely out of neutral forward and reverse) and the outdrive will go into neutral. I adjusted the shift cable and control cable per instructions and problem presists.<br /><br />Problem does not happen when shifting on the trailer. Problem does not happen when shifting on the trailer with muffs and engine running. Problem only seems to happens when engine is running and boat is in the water.<br /><br />Any ideas?<br /><br />Thanks in advance for any help. You have helped me tremendously in the past.
