Shift Rod Height For 1985 Johnson 40 Hp
kaimalie
Helped A Friend Do A Water Pump Job 1! Some Where In Between The Job A Friend Decided To Check Out The Shift Rod. Now The Engine Only Has The Forward Gear
ezeke
Re: Shift Rod Height For 1985 Johnson 40 Hp
Standard shaft - 15-29/32 +/- 1/32
Long shaft - 20-29/32 +/- 1/32
Gearcase in neutral, measured from the gearcase mating surface to the center of the hole at the top of the shift rod.
kaimalie
Thank You For The Help ! I'll Have My Friend Try It Out. I'll Let You Know How It Goes !!!
