OK, so i replaced the water pump on my '75 johnson 50hp. I am trying to reassemble the lower unit to the exhaust housing. I have all the lower bolts on, I go to re-attach the shift rod to the lever, and the shift rod is about 1/2" short of where the bolt goes through!? Did I do something wrong? Is there some trick to getting the rod lined up and in the slot?<br />Help!
