Shift rod problems
Blake0912
I replaced my water pump today but somewhere in the process i must have turned my shift rod, and now i cant get it to line up. So it wont go in gear at all. My question is how do i figure out what the correct position for the shift rod is? The motor is a 1988 Johnson 88hp spl. Thank you.
N1NE1
Re: Shift rod problems
you should be able to adjust it with the end of the shift cable coming from control box on the motor side,loosten the 3/8 bolt holding the 2 cables in place and turn to direction you need whether its in or out
wilde1j
The adjustment must be made in the shift rod length, not the cable trunnion.
Blake0912
Thanks for the replys I figured it out. The length was not the problem I had the shift rod on the right side of the linkage and not in-between the fork like thing so the pin was not engaged causing it not to shift. I had the seloc manual but it does not mention anything about connecting the linkage back Up. That Manuel is a POS.
seasprayralph
One other thing to be aware of is that if the shift rod has an offset at the top,, this must face the driveshaft
