Shift rod problems
FishnHunt9
I have a 97 johnson 40 hp and went to change the impeller, not knowing at first to take bolt off the top of the shift rod we may have done something to the shift rod now it will not come out of forward is something wrong or broken at bottom of shift rod or is it just in wrong?
FishnHunt9
Re: Shift rod problems
by forward I mean It wont go into neutral or reverse its stuck in forward. we did remove and put back the drain screws and that may have allowed the shaft rod to move.
boobie
Have you got the shift rod back in the G/C or what ?? Damn. I hate those OEM Factory Service Manuals!!
FishnHunt9
the shift rod never left g/c we started working without a manual and got one in the middle of the job and the damage had already been done.
boobie
Was the upper shift linkage still connected when you pulled the G/C off??
FishnHunt9
It was connected we tried to force it off then put it back togethter and read to take the upper shift linkage off we then removed it and it will not come out of forward.
boobie
Sounds like it's lower unit tear down time.
FishnHunt9
Yeah I think so, I'm taking the lower unit to a Johnson dealer tomorrow.
OptsyEagle
Did you try turning the propeller or even the flywheel a little while trying to shift? Admittedly, that trick usually helps a lot more when trying to get it into gear, as opposed to getting it out of gear.
kodibass
Master Chief Petty Officer
once you remove the lower unit & try to manually cycle thru the different gear positions with the lower unit detached, If you are unable to do so something most likely busted.
FishnHunt9
the cradle where the bottom of the shift rod fits into had gotten spun around backwords when loosened up one of the screws in the lower unit, the one that holds shift rod in proper place. So 2.5 hours of labor later the johnson evinrude technician had the cradle back in correctly and shift rod adjusted to proper height and functioning correctly. He had to go in through driveshaft to get the cradle back in correctly.
boobie
That's why I like OEM Factory Service Manuals. I won't even work on my own mtr without one. Or any of my vehicals.
hsdtech
Glad you got it back together. Would you mine letting me know what the dealer shop cost was? I'm in the same boat (no pun intended!) and know what has to be done, I just don't have the time or patience right now to do it myself. I know different shops in different areas charge more/less, just curious at what they charged you. Thanks.
